Quote Originally Posted by jbalcorn View Post
(I usually like to keep my ph a little high - 7.6-7.8.) Chlorine was all gone.
Shocked the pool 2 days ago (TC up to 15), and now water is cloudy, but white.
Numbers from this morning:
FC: 11
CC: 0
Ph: 7.4
CYA: 50
Alk: 160
Temp: 78
Last year, I had my CYA lower, my ph higher and although I had to add bleach a lot, the water was crystal clear.
Any idea where the cloudiness is coming from? I thought it might be dead algae, but the filter should have taken care of that, right?
What did you use to shock with? You don't give a hardness level, but with high pH and alk, if you used cal-hypo to shock and have a high hardness level, it may very well be a calcium cloud.
