Re: Cloudy Pool
You don't need to change your sand unless you had baquacil. Most of us have had our sand for many years/Your water is probably cloudy due to algae. You need to get your chlorine up to shock, which at a cya of 40 would be 15ppms. You need to check your chlorine level 3x a day and get it back up to 15 each time to kill off the aglae - do this until your chlorine holds overnight. It m
ay take a couple of days.
Northeast PA
16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
