Thread: Letro Legend Not Moving Around Well
    Katy, TX
    Default Re: Letro Legend Not Moving Around Well
    Look in the manual on the part about pointing the jet on the rear end of the legend.
    Michael
    Thanks Michael. My husband has adjusted that several times and just can't get it to work. Any other ideas?
    Thanks.
    PAT
    Make sure that the float is not cracked on the top of the unit. Mine was and the unit would tend to tip over and it would not run straight. If your float is cracked you can use a 3 or 4 inch piece of pool noodle as a temp fix. Taped on with duct tape. The float should only be big enough so that the unit sinks but it stays upright with all four wheels on the ground when the unit is not running. Too big and the legend won't sink or runs with the back end up in the water.
  1. Help with Legend II install
    By castagnolac in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-27-2010, 06:20 PM
  2. Letro Lehend II hose?
    By AE340B in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-08-2007, 12:56 AM
  3. Pentair Legend
    By Ready2swim in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-04-2006, 01:18 PM
  4. Pentair Legend II / Letro Legend II
    By angela_o in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-24-2006, 03:46 PM
  5. Polaris 360, Letro Legend II... Do you leave in the pool?
    By leejp in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-19-2006, 07:25 PM
