Thread: Adding DE to Sand Filter; I Know, I know but idea not addressed in Sticky above
    Default Re: Adding DE to Sand Filter; I Know, I know but idea not addressed in Sticky above
    Agreed, dumping it into the skimmer is as easy as it's going to get.
    Also, I think there are more variables than just the amount of sand you have when determining how much to add. Pump size and plumbing for example. I notice a reduction in pressure at my returns and drains if I add too much even though the psi at the filter has only risen a couple points.
    I'm down to adding only half a cup (about 6 ounces). Anything more and things start acting funny.
    MikeInMo is offline ** No working email address ** MikeInMo 0
    Oct 2004
    Well it took 5 and 1/2 cups to get a tad more than 1psi increase.
    Took forever doing it a half cup at a time with 20 minute pauses between each new addition. Still amazed at the amount it took even given the size of my filter. Course last year I rarely had to backwash because the filter is somewhat oversized.
    Didn't see any floaties in the water, neither DE nor the normal things I was seeing float in front of the lights. I'm looking forward to seeing what it will look like tomorrow afternoon.
    Is there something wrong that I needed that much DE?
    Keep checking your pressure! Mine takes a lot longer than 20 minutes to increase... sometimes a couple hours.
  1. Adding DE to a sand filter
    By AnnaK in forum Pool Equipment & Operations
    Last Post: 07-18-2012, 07:50 PM
  2. Adding DE to sand filter
    By The Raddish in forum Pool Equipment & Operations
    Last Post: 06-04-2008, 05:36 PM
  3. Adding DE to sand filter FAQ
    By Unabomber007 in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 08:59 AM
  4. Adding DE to sand filter
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-28-2006, 05:14 PM
