Results 1 to 10 of 11
Thread: Autopilot Pre-sales Questions
Threaded View
  1. #7
    Default Re: Autopilot Pre-sales Questions
    Thanks for the info.
    1. Whoops. I must have had the Pool Pilot cell size on the brain. My pool size is 14,000 gallons, so I'm guessing the smaller size would work if I chose to go that route.
    3. My mounting location would be on the side of the house next to the timer, so it should be okay although I may consider some options to protect it. I assume I would need to maintain adequate air flow if I shielded it somehow.
    4. I suppose I would replace my timer since it has that capability. But does it have also have a switch to shut the heater off to allow it to cool prior to shutting down the pump?
    Again thanks for the info. This is really making my decision tough. The Intellichlor looks like it would take almost no time to install. The Pool Pilot appears to be technically superior, but the installation is a little more involved. The PoolPilot has a field track record; the Intellichlor not so much. Advantage PoolPilot on cell replacement cost. Advantage Intellichlor on initial acquisition cost.
    Having someone on this forum is a big plus for the Pool Pilot. On the other hand, prior to posting these questions yesterday, I sent emails to both Intellichlor and AutoPilot. I got a quick response today from Intellichlor, but have yet to hear from AutoPilot. (Having you here to answer questions beats email anyday, but I thought you might want to know that.)
  1. Sales Not Allowed
    By traceyb in forum Pool Equipment & Operations
    Last Post: 05-16-2009, 10:38 AM
  2. Leslies sales tactics
    By poolaris in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-14-2008, 04:54 PM
  3. Autopilot Installation Questions
    By donaldm823 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-13-2007, 11:25 AM
  4. autopilot install questions
    By jmcst25 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-09-2007, 11:33 AM
  5. Autopilot Questions for Sean
    By msjulian in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2007, 02:51 AM
