Thread: Low PH and Alkalinity
    mbar's Avatar
    Ashland, PA
    Default Re: Low PH and Alkalinity
    Try adding 2 cups, wait 2 hours, test again and see how much it went up - then take it from there.
    Northeast PA
    Jul 2006
    NC
    Quote Originally Posted by mbar View Post
    Thank you!
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Ph or Alkalinity...which should i fix first
    By JKashJ in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-11-2008, 05:18 PM
  3. Alkalinity Low??
    By Brunomax in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 03:23 PM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 11:03 PM
