Results 1 to 9 of 9
Thread: Just Opened Up - Clogged Pipe??
    NJ
    Default Re: Just Opened Up - Clogged Pipe??
    I actually went ahead & blew out all the lines with a stronger shop vac & everything is clear, except for the main drain.
    I then took apart my DE filter, & cleaned it. The problem was it was extremely dirty so the water had no where to go.
    It working fine now, except for the main drain. I can't see down there, the water is green. I am in the process of rigging up a setup to blow out the main drain.
    Thanks, now I need to work on getting the water clear & clean.
    Jul 2006
    Nova Scotia CANADA
    it's interesting that I'm having this same problem ( clogged pipes)
    perhaps I'll try the shop-vac method... thanks
    NJ
    I rigged a setup for the main drain, through the pump basket, and I can't get any air bubbles out of the main drain!
    Are there any other ideas?
    Jul 2006
    Nova Scotia CANADA
    Hey wetshoes
    I found out what was wrong with my system... turns out it was not a clog,
    it was actually a very small air leak.
    we had forgot to put the O-rings (rubber gaskets) in our attachments ( & possibly one of the hoses wasn't exactly threaded correctly)
    anyway, this tiny airleak ( coupled with the water level not being overly high, but just at minimum required level), caused the system to not prime correctly
    so I guess I'm saying, check all hoses and connections for possible leaks because it could really be that you are just drawing in some air
  1. clogged pool filter
    By brutuszada in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 12:22 AM
  2. Skimmer clogged
    By Graves in forum Pool Equipment & Operations
    Last Post: 05-24-2011, 01:42 AM
  3. Clogged suction line.
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 06-07-2007, 12:00 PM
  4. Help with clogged impeller
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 11:54 PM
  5. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
