Thread: Jacuzzi CE60 Model K Pump Shaft Leak - Replace?
    May 2010
    Thumbs up Re: Jacuzzi CE60 Model K Pump Shaft Leak - Replace?
    I have the Jacuzzi DE filter with 2 speed motor. Mine was about 4 years old and had a leaking seal. It is a $10.00 ceramic faced bearing seal. Took about 45 minuetes to replace. Cheap part and easy fix. Go for it.
    Honesdale PA
    Default Re: Jacuzzi CE60 Model K Pump Shaft Leak - Replace?
    If you feel comfortable digging into it, follow redhots advice (and welcome to the forum redhot). For $10 what do you have to lose by trying? As for compatability of a new pump, you may have to do some replumbing but with PVC you can mate anything to almost anything. If you decide to do that check here first for sizing recommendations.
  1. stubborn leak on hayward super II pump - repair / replace?
    By jml999 in forum In-Ground Pool Construction and Repair
    Last Post: 04-13-2012, 03:18 PM
  2. Pump shaft bent
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 06-26-2010, 07:30 AM
  3. Jacuzzi pump leaking at motor
    By poolbee in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 09:26 AM
  4. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 12:06 PM
  5. Jacuzzi model 190L PROBLEM HELP
    By sisie5 in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 10:35 PM
