Looks good, but keep an eye on your CYA if your going to use tri-chlor. It will be up over 100 in no time.
Here are my results:
Ph 7.2
TA 80
FC 14.5
CC 0.5
CYA around 80
I use bleach to shock and tri-chlor as my usual chlorine...still trying to finish off the huge buck from wholesale club.
How do the numbers look?
I put in a gallon of bleach about 2 hours ago before testing not sure how long that takes to build up the chlorine.
Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
I wouldn't use those trichlor pucks with a cya of 80. You don't want your cya any higher. We usually recommend a cya reading of 30-50.
