Results 1 to 10 of 13
Thread: how much CYA will a 50lbs of tri clor add?
    Default Re: how much CYA will a 50lbs of tri clor add?
    The formula is about 3.3 ppm CYA for 8 ounces in 10,000 gallons. So,
    3.3 * (7/8) * (10000 / 27038) = 1.07 ppm CYA per 7-ounce puck in 27,038 gallons. The accurate calculation gives 1.08 ppm CYA (the 3.3 was rounded).
    I'm not sure what you were looking for.
    Richard
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Unhappy Re: how much CYA will a 50lbs of tri clor add?
    At 1.07 ppm CYA/7 oz puck it should take ~ 9.3 pucks to raise it 10 ppm. We have put 12 pucks in and have not seen the CYA budge. Tests this AM were:
    pH 7.4
    FC 3.6
    CC 0
    TA 90
    CYA <30 ppm
    Temp 83
    All with Taylor 2006 kit
    Maybe the CYA was lower than we thought (22) to begin with. I just want to "quit with the pucks already" --- they make a black scum ring around the pool and I didn't have that when the CL Pump was in use.
    I sure wish there was a different test for CYA -- I just got off the phone with them --- NOPE --- unless you go electronic colorimeter (Taylor doesn't have) and it is still turbidimetric.
    27038 Gallon InGround, Vinyl, DE filter.
    Though Trichlor is cheaper, a faster and more efficient option for adding CYA is Dichlor. At least it dissolves right away. Anyway, I found that using Trichlor in my own pool took a little more than I expected to get the CYA to rise, but the turbidimetric test is clearly not precise visually and is probably quite prone to error at the lower CYA levels where other turbidity of the water itself would become even more important.
    CYA presumably adheres to pipes and pool surfaces, at least somewhat, so some that gets added probably doesn't get measured in the water test.
    Richard
    Central Texas
    I'm probably wrong here, but I -think- adding 50 pounds of Trichlor will add about 25 pounds of CYA. Then you could just use the dilution table on the back of the container of pure CYA at the store to figure out how that affects your own pool.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    That's pretty darn close. 50 pounds of Trichlor is equivalent to 27.8 pounds of CYA in terms of its CYA content (i.e. these stated amounts both raise the CYA by the same amount) -- 332.8 ppm CYA in 10,000 gallons -- obviously way more than anyone would want.
    Central Texas
    Yeah, I rounded off. I asked DuPont about this last year and they said each puck was 56% CYA. 50 pounds times 56% is 28 pounds.
    Tom Wood
  1. A&A Quik Dek-Clor Questions
    By kluczenk in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-14-2010, 07:08 PM
