Re: Re-occuring Metal Problems
I don't know of anything that permanantly gets rid of metals in the water. However, what I suggest is to do the ascorbic acid treatment, add enough sequestereing agent - a little more than the bottle recommends, just to be on the safe side. After all of the stain is gone, and you have the sequestering agent in, add some flocculant. Let the filter off for 24 hours, and let the water settle out. Vacuum to waste. If you need to add water to your pool, add it into the skimmer with a trichlor puck in it only if you have a sand or DE filter -DO NOT DO THIS IF YOU HAVE A CARTRIDGE FILTER. THis way when well water hits the chlorine if there is any metals going to fall out it will stain the filter first. I assume you are using well water and that is how metals are introduced to your pool. If not, then it would be a good idea to find out where the metals are coming from, so it will be easier to deal with. Keep your ph in the 7.2 range - you will have trouble keeping it at that level until all of the ascorbic acid is gone - chlorine will be used up fast too. You want to add chlorine slowly, do not shock for at least 2 weeks after an ascorbic acid treatment - you can add some polyquat algaecide before you start the treatment if you are worried about getting algae. Hope this helps - let me know if you have any other questions
Northeast PA
