Results 1 to 8 of 8
Thread: Replaced spider gasket now leaking from waste
    Attleboro, MA.
    Default Replaced spider gasket now leaking from waste
    Today I opened my pool and started the filter and water was leaking from the waste. I replaced the spider gasket on the filter. It is the correct spider gasket. I put the lubricant on it, maybe too much or not enough? Not really sure what the heck is going on. I can't put the old gasket back in because it was glued in or melted in so I had to break it apart to get it out.
    Am I doomed or will maybe the gasket end up compressing and working? Any suggestions would be appreciated.
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    Default Re: Replaced spider gasket now leaking from waste
    Perhaps you also need a new spring to put the right amount of pressure on the gasket ???
    Central Texas
    You could also install a valve in the waste line.
    TW
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Attleboro, MA.
    I read in another thread that putting a ball valve could be dangerous because of a buildup of pressure. Is that true?
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    I do not recommend putting a valve on the waste (backwash) line to stop a leaking spider gasket. I tried the same think and ended up with a pressure buildup in the backwash line that caused the backwash sight glass to leak. You should get the spider gasket fixed.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Attleboro, MA.
    I called the manufac. of the filter, Astral. They said I need to glue in the spider gasket with super glue. I just glued it in. Haven't installed it back in yet not sure how long I'm supposed to let it dry for. I'm hoping that fixed the problem but we'll see.
    matt4x4 is offline Lifetime Member Whizbang Spinner matt4x4 2 stars matt4x4 2 stars
    Hi Nicole,
    Superglue (CA Glue)may not be the perfect solution, it should last for some time, however, chlorine will attack it and break it down faster than contact cement. also, the gasket is flexible, the super glue is not, seperation issues may occur.
    Just note that ifd it starts to lak in teh future to reglue it using contact cement
    Attleboro, MA.
    Well it's still leaking. Really bad at first then I shut off the filter move the gasket through the positions and then turned the filter back on and it was down to a drip. I let the filter run for about 1/2 hour while vacuuming and by the time I was done with that it was still dripping but not as frequently.
    I took it back out and wiped off all of the lubricant and also cleaned off in the valve assembly the plastic the gasket sits on. There was some old residue on it that had to be scraped off with my fingernail. Just going to try it and if the leak stops maybe I'll take it back off when I'm going to switch the filter to backwash and put a little bit of lubricant on.
  1. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  2. Spider Gasket
    By markphin in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 01:18 PM
  3. Hayward spider gasket...uh missing?
    By scarywoody in forum Pool Equipment & Operations
    Last Post: 06-07-2007, 01:03 PM
  4. Spider Gasket - First Obsticle
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 10:31 AM
  5. Replacing Spider Gasket
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 11:49 AM
