Results 1 to 8 of 8
Thread: Left pump out all winter in MO, dead now...
    Thumbs up Re: Thx waste!
    Quote Originally Posted by waste View Post
    Sauce, does the motor hum, or is it completely dead?
    You can try to power it up and give the motor a couple of good raps with a 2X4 - this could 'free up' a rusted starter switch.
    If it hums, turn off the power and open the pump lid, remove the basket and try to use a screwdriver though the back hole to turn the impeller, if you can get it to turn, replace basket and turn the pump on again - it should start drawing water.
    If neither of these work, I'll try to describe a couple of other ways to do it. Actually there are some links I'll try to find which may help..
    (not to be offensive, but is the breaker for the pump on, check to make sure it didn't just trip out)
    Waste... you were right on man!
    At first, it didn't make a noise when I plugged it in... so I took your advice and whacked it... then it hummed. So then, I unplugged and got the impeller to turn like you said, plugged back in, and it was working like a charm!
    You saved me a lot of time and $$$! Thanks!
    This winter I'm taking it inside though
    Cool Re: Left pump out all winter in MO, dead now...
    Sauce, glad to have helped but I've got to give credit for the 2X4 trick to Poconos (and perhaps Matt and/ or Mas & maybe even others) - I didn't know about the starter 'freezing up' till I saw a couple of threads where it was mentioned.
    NY
    Talking Re: Left pump out all winter in MO, dead now...
    Are you talking about an AG pump? My builder closed my pool this winter and all equipment was left outside. We were told not to cover the heater because it makes it more inviting to unwanted guests(mice, etc.). I live near Buffalo,NY. It is occasionally cold and sometimes snows
    Default Re: Left pump out all winter in MO, dead now...
    my 2 cents..if i had a heater/pump outdoors, once drained well, i'd cover with secure plastic.
    Poolbee, type of pump isn't all that important, they all work the same - however, if you have a DoughBoy, the motors are shrouded and should minimise the effects of being left out all winter. (BTW - my brother lives in Jamestown and either you don't get the same weather or are a master of litotes).
    What kind of heater do you have? The mice don't destroy all, they just get fried when it fires (:evil grin
  1. The pump is dead, long live the pump!
    By maryberrye in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2011, 01:38 PM
  2. Taylor Kit Left out all winter
    By cooper in forum DPD-FAS based testing
    Last Post: 05-22-2011, 07:42 PM
  3. Help! Left on vacation and once back pump won't prime and Guests coming over
    Last Post: 09-23-2008, 06:23 PM
  4. Dead pump emergency
    By ljh in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2007, 09:32 AM
  5. I think my pump might be dead......
    By farmgirl in forum Above-Ground Pool Construction & Repair
    Last Post: 04-03-2007, 01:26 PM
