ndillon2,
It sounds like your've not only got high CH, but also high pH and TA and that combination will often lead to scaling. The solution is most likely to lower your TA significantly. If you post your numbers (including FC, CYA and temp) we can see if this is what is happening and propose a solution.
Richard
