Results 11 to 12 of 12
Thread: Testing chlorine when shocking
    Guelph, ON, Canada.
    Default Re: Testing chlorine when shocking
    I like to use a syringe to measure out the volume of the pool water and distilled water. These are readily available at the drug store for dispensing childrens medicine.
    I run a SWG which recommends CYA at 60-80ppm. Using Ben's Best Guess chart this means when I do need to shock, I have to increase Cl to 20ppm.
    At this level, the amount of chlorine in the tap water is almost insignificant, so I use tap water instead of distilled.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
    Nashville, TN
    You can get large syringes At any TSC or COOP or where they sell animal supplies. Of course the needles are sold separately which is ok with me.
  1. New Pool Owner, No Chlorine less than 24 hours after shocking.
    By DistantHorizon in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-14-2011, 08:57 PM
  2. Shocking a Bromine pool - can I use chlorine shock
    By Needzo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-21-2010, 07:39 AM
  3. If chlorine is kept at proper level, is shocking ever necessary?
    By Hubjeep in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2007, 05:14 PM
  4. PolyQuat and Shocking with Chlorine
    By chem geek in forum The China Shop
    Last Post: 11-27-2006, 03:35 AM
