Using Ben's kit here are my results:
Ph 7.5
FC 2.5
CC 0
Alk 90
Cal 130
CYA 0 (pool store said I had 70--but I have tested and retested)
Salt 3000
Last week my Alk and Ph were not right (alk 50 & Ph 7.2) and I had let my FC drop so I had some algae growth. So I used baking soda to adjust my TA and kept the pool at shock levels...but the pool still had not cleared up. So, I was adding some DE to my sand filter to see if that would help, but I accidentally put in too much and it blew past my filter. I have been vacuuming that up as it settles to the bottom of the pool.
So, now the shallow end is clear but in the deep end it is still a little cloudy.
What should I do now???
Should I add enough CYA to get all the way up to my SWG's recommendation of 60-80?
And my SWG also recommends Cal of 200-400, I have a liner pool so I haven't worried too much about my Ca being low. Should I adjust it or leave it alone?
Thanks!!!!!!!!!!!
Kay
(are you sure the landscaper didn't pay you a quick visit
