Thread: foamy bubbles?
    bhelme's Avatar
    bhelme is offline ** No working email address ** bhelme 0
    Baltimore, MD
    Exclamation foamy bubbles?
    Everything was great until the pollen hit big time and my filters got really clogged (in less than a week). SWG stopped generating because the flow was too low. Noticed bubbles/foam on the surface and water had started to cloud. Was able to clean it all out yesterday and all operations are normal. Dumped a bunch of bleach and the water is now mostly cleared up, but the bubbles/foam are still there.
    Today's readings:
    FC 5
    CC 0
    TC 5
    pH 7.4
    Alk 100
    Cal 450
    Cya 20
    Temp 80 degrees
    Salt 3200
    I have added Morton's solar salt, bleach, and muriatic acid this year, except I also used up the last three little bags of Mineral Springs that I was sucker enough to buy before I really read about SWG's in the forum. Could that be causing the problem? Or do I have an algae problem and need to get my FC way up there to shock that stuff I let grow in the 3 days I wasn't able to keep an eye on things.
    bhelme's Avatar
    Baltimore, MD
    Default Re: foamy bubbles?
    Well, 8.5 gallons of bleach later and the bubbles have nearly disappeared, so I guess it was algae related after all. Wish I could blame the Mineral Springs instead of my neglect in checking the filter for three days (I hate this pollen!).
    tenax is offline Registered+ Widget Weaver tenax 0
    last year, i put a bunch of algaecide in at one time and got tons of foamy bubbles...i was panicked at first but yep, over some days, they went away
    Chell is offline ** No working email address ** Chell 0
    Unhappy Re: foamy bubbles?
    So a quick question,
    To much algaecide will cause the water to look kinda cloudy and cause bubbles? when you move around in the water or back flush it, it will create a lot little bubbles?
    I haven't put bleach in it because I was scared to do anyhthing else to it, will 8.5 gallons of bleach help straighten it out?
    Haave pool party this sunday and would love a qucik fix if possible, Thanks
    The water was green and I put the algaecidein to clear it up and I believe I over did it a tad. I let my teen age dauaghter put it in while I was at work and she put two gallon in a 14,000 gallon pool!!!!!!!!
    what i had what was bubbles coming out of the return and then they turned into foam on the surface when i used too much algaecide..first time i ever had that. probably put a gallon of algacide in vs a small bottle hoping it would clear things up quickly..
    when i've had bubbles coming out of the returns, it's been because i have air in my pipes or pump..usually the pump.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Chell, you said you only put in algaecide? You have to put in bleach, algaecide will help to prevent algae, not get rid of it. You should post a full set of numbers so we can help you. Too much algaecide can cause foamy water, but there are other reasons for it too.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
  1. foamy
    By rick4dis in forum Dealing with Algae & Slime
    Last Post: 06-11-2012, 02:58 PM
  2. foamy pool
    By cruzadin1121 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-10-2012, 03:25 PM
  3. Green, cloudy and foamy is no way to go through life, son
    By davidb in forum Dealing with Algae & Slime
    Last Post: 07-31-2011, 11:11 PM
  4. foamy water
    By DrSteveF in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 07:35 PM
  5. My Screw UP = Foamy Mess
    By lm8838 in forum Dealing with Algae & Slime
    Last Post: 06-07-2008, 03:54 PM
