Results 1 to 10 of 12
Thread: Possible to separate pipe from valve body??
    Default Re: Possible to separate pipe from valve body??
    Sounds good but does it significantly reduce flow?
    Thumbs up Re: Possible to separate pipe from valve body??
    Joe, you're right that you'll be restricting the line some, but the amount is small. I use them when the cost, to the homeowner, for a whole new valve(s) is gonig to be too much for them. In my experience the restriction has a negligable effect on the system's performance.
    Thanks for the reply. I am not moving huge amounts of water either. I have a Pentair Whisperlo 3/4hp which using an average of 50ft of head only flows about 70gpm. The valve draws from two 2" pipes (skimmer/main drain) and outputs to one 2" pipe that leads to the pump/filter which is an FNS PLus.
    Given that info still the best approach?
    So he used glue in valves? Jerk! I'm assuming you mean a ball valve, not the filter's 6 way valve.
    I would bite the bullet and replace the ball valve with one with threads on the inside. Then you glue a threaded nipple onto fresh PVC and do what you need. They also sell double-male fittings, both long and short in 1.5" lengths. That means it's already threaded at both ends and you don't have to make your own.
    You're right, it's a Jandy ball valve. Lots of work to replace it though since it connects to another ball valve .
    I was looking at the valve again and if I cut very close to the current elbow I would have about 11/16" of free straight pipe coming from the valve. Is that enough to get a decent seal?
    Thanks,
    Joe
    Honesdale PA
    Yes on the seal. Not ideal but it will be fine if you make a good joint.
  1. Separate pump for heater?
    By DrMacZed in forum Intex-type Pool Setup & Operations
    Last Post: 07-27-2012, 02:01 PM
  2. Cost of separate color for Pebble Tec with Tanning Ledge and Beach Entry
    By jeremywitte in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2012, 06:07 PM
  3. Does Muriatic Acid and Water Separate
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2008, 02:08 AM
  4. separate pump & filter?
    By meade in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-25-2006, 04:29 PM
  5. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
