Results 1 to 8 of 8
Thread: Aeration and its effect on pH
    mbar's Avatar
    Ashland, PA
    Default Re: Aeration and its effect on pH
    Your numbers are great. You didn't post your cya - this is what will determine how high you need your chlorine. Chlorine at 1 - 2 is ok if you have almost no cya. Here is a good chart to follow, there is a sticky at the top of the chlorine forum:
    Use the info in this chart to help you figure out what levels of chlorine you need to maintain in your pool based on the amount of CYA (cyanuric acid, also called stabilizer) that you have in your pool. (FC = free chlorine)
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    As far as the suds go - I think they will be gone soon, as long as everything is good with your filter
    Northeast PA
    Mandeville, LA, USA.
    I think your TA is fine, especially with very low levels of calcium (what is the calcium level, by the way?).
    Oct 2004
    NJ, USA.
    Thanks Marie and Kurt for the helpful advice and words of support.
    Kurt ....... I really can't tell what my calcium level is. All I know is that it is so low that my Taylor drop tester can't determine the level. When I set up the test, the color starts off as a purpleish blue (not red as the instructions indicate) and does not change.
  1. Question about Trichlor effect on TA and pH
    By Chuckles76 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2013, 05:54 PM
  2. Low PH-10Lb of Borax Had No Effect
    By NAPA242 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2012, 10:44 PM
  3. Aeration and CL drop
    By Pamsel in forum Dealing with Alkalinity and Calcium
    Last Post: 06-23-2006, 11:46 AM
  4. How long for muriatic to take effect?
    By BillyBumbler in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2006, 05:59 PM
  5. SG effect on aluminum?
    By kjmelak in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-17-2006, 12:28 PM
