Thread: have numbers ready for cya?
    Question have numbers ready for cya?
    Ok here we go have 2-bottles of cya 1.75 lbs each. have some floating pucks and here are my numbers
    fc-0
    cc-0.5
    alk-80
    ph-7.2
    cya-0
    with the cc at 0.5 should i get this to 0 before adding cya or start the cya and and chlorine also. by the way baq to chlorine conversion almost done. water is like mid summer very clear. Im going to mix one bottle in water pour in skimmer, the other Im going to put it in a sock and put in skimmer basket or hang over the side of the pool , does this all sound ok also wait for a week before testing cya? I think Im getting this process,
    Default Re: have numbers ready for cya?
    Quote Originally Posted by larry b View Post
    fc-0
    cc-0.5
    alk-80
    ph-7.2
    cya-0
    You can go ahead and add the CYA, but if you still have CC, your chlorine should not be zero. (Your chlorine should NEVER be 0). Take it back up to shock level, and hold it there until the chlorine level holds overnight. IN the meantime, your CYA can be dissolving.
  1. Ready to learn
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-16-2010, 09:54 PM
  2. getting ready for Gustav
    By mspool in forum Pool Equipment & Operations
    Last Post: 08-29-2008, 12:59 PM
  3. Getting ready to dig it up - talk me out of it.
    By Miataguy in forum In-Ground Pool Construction and Repair
    Last Post: 12-10-2006, 08:57 PM
  4. So, am I ready to ROCK???
    By Pool_Mike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-22-2006, 11:01 AM
  5. I am ready for BBB. My numbers are...
    By slater1182 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2006, 06:20 PM
