Oh, I see what you mean. The "suction" from the falling water reduces the pressure at the top, but not quite enough to make it negative (that is, below atmospheric). The term "negative head" confused me. I would think of it more in terms of "head reduction".
However, I am still not sure this works. You're saying that I would use the pump at high speed to fill the pipe, then I can switch to low speed. But you also agree that even with low speed there is higher-than-atmospheric pressure in the pipe at its highest point (where the valve is located). That means that at low speed the pump still has enough power to fill the pipe, and I don't need two speeds, just the low speed.
Anyway, thanks for your help and advice. I will have to do some measurements and calculations and see if I can get by with a smaller pump.
