The recommended range is 30-50 ppm for most people. SWGs require a higher level (but not a higher FC level usually), and some people in very hot, sunny climates run it a bit higher with a higher FC level to minimize chlorine loss from the sun.
Edit: I'd start at the 30-50 ppm level and see how it goes. You can always bump it up a bit if you need to. If you have a SWG then run it at the high end of the manufacturer's recommendation.
