Results 1 to 5 of 5
Thread: Pump leak
    Jul 2006
    Shepherdsville, KY
    Default Pump leak
    Hello all! I just opened my pool up yesterday (yay ) and I noticed something about my pump. When it is turned off it leaks around the rim, but when it is turned on it doesn't. I have cleaned and oiled the o-ring and the rim and it is still doing it. It seems like it is just not sealing all the way around. Any suggestions?
    Indiana.
    Default Re: Pump leak
    Tighten it or get a new O-ring. That's normally the way it acts when it isn't sealed.
    Jul 2006
    Shepherdsville, KY
    The o-ring looks to be in good condition so how do you tighten it?
    Indiana.
    Quote Originally Posted by circlenranch View Post
    If you can't put the pump basket lid on tight enough to keep it from leaking, you need a new O-ring. The O-ring needs to be greased on both sides with O-ring grease to allow it to stay in position while the lid is tightened.
    Jul 2006
    Shepherdsville, KY
    OK. Thank you for your help!
  1. pump leak
    By reebok in forum Pool Equipment & Operations
    Last Post: 09-02-2012, 07:56 AM
  2. Pump leak
    By chumpy36 in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2011, 05:24 AM
  3. Pump leak?
    By Bnelson in forum Pool Equipment & Operations
    Last Post: 05-26-2009, 03:20 PM
  4. leak in new pump?
    By Garvacious in forum Pool Equipment & Operations
    Last Post: 03-26-2009, 08:12 PM
  5. Pump Leak
    By rilesworld in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2007, 07:36 PM
