Hi all! I'm baaaaaaaaccckkkkk.....LOL! We just uncovered after our first winter with a pool. At first I was scared because the bottom was green (but I could see all the way to the bottom which I knew was good). But after a good vacuuming to waste, the water looks GREAT! We added our DE, shocked, and then tested: Here is what we got:
TC-3
PH-6.8
ALK-280
CYA-60
So I used Muriatic Acid to bring down the ALK to 160 (I know I should go further), however the PH stayed at 6.8. I now need to raise the PH so how much BORAX should I use? After my initial shock treatment, I plan on using liquid bleach (used pucks last year because I already bought a huge thing before I found this forum). My pool is 15x30 AGP with 46 inches of water for a total of about 11,000 gallons. So how much Borax and how much liquid chlorine should I use on a daily basis?
Thanks soooooooooooo much!!!!
