Thread: Vaccuum always hangs on stairs
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    Default Vaccuum always hangs on stairs
    I have a zodiac Kontiki automatic pool cleaner for my ABG pool. It's a hassle using because I have to baby sit it because it always get caught on the stairs, sometimes I think I'd be better off using a manual vac head. Anybody able to solve this particular problem. I recall the manual saying you could get a larger ring to help if this became a problem, but I;m not really sure how a larger ring would help me ????
    thoughts????
    Pool newby
    18' AGP, 200# sand filter, 1.5 hp 2 speed BaquaPure pump
    Default Re: Vaccuum always hangs on stairs
    it's a typical scenario - especially with drop in steps.
    I found that in most cases, it happens when the hose pushes through the handrail uprights, at this point the vac decides to stick near the stairs.
    I am in the process of tying in some plastic lattice between my handrail uprightsthat should keep the hose from travelling into that space and the vac should also be aided in finding it's way out of that area.
  1. How to weigh-down stairs?
    By Steveromo in forum Pool Equipment & Operations
    Last Post: 05-30-2012, 11:15 PM
  2. staining of stairs
    By Moersie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-18-2011, 12:53 PM
  3. Aceman's new stairs
    By waste in forum In-Ground Pool Construction and Repair
    Last Post: 12-31-2008, 05:51 PM
  4. Polaris runs but won't vaccuum
    By bayshorebevo in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-29-2007, 10:22 AM
  5. Stained stairs
    By jagwire22 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-07-2006, 11:17 AM
