You can have clear water, and something starting to grow in the water that is using up your chlorine. If you don't get it to shock till it holds overnight, you will battling this for a long time. Get a couple of bottles of bleach and put them in - it may take a lot. Your water is probably clear because you haven't gotten to a big algae outbreak yet. This happened to me a couple of summers ago - it took a really good shocking to get rid of whatever was trying to take hold. Use the bleach calc to see how much you need for your size pool, with your cya level
