Thread: Homemade chlorine generator
    Hurst, Texas, USA.
    Default Homemade chlorine generator
    I've been looking to get a SWCG system for my pool, but I just can't afford it at the moment. I got to thinking about it and it just doesn't seem that difficult to generate chlorine via elecrolysis. Low voltage over a non reactive substance (titanium or maybe even better graphite plates) and enclose it.
    The reaction produces hydrogen, chlorine and caustic soda. The only problem that I can see is a potential build-up of hydrogen gas, but this seems minimal given that the gas is not exposed to oxygen. I could be way off here, so I am wondering if any of you have anything to add.
    Indiana.
    Default Re: Homemade chlorine generator
    Sure, it would be easy. But I'm an electrical engineer and I wouldn't swim in a pool with such a device I had designed in operation unless it had been thoroughly tested and evaluated to verify that a component failure couldn't result in high voltage or current being applied to the water. Such testing would cost far more than a SWCG sells for on eBay.
  1. What's the most reliable chlorine generator>
    By mikeps in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-06-2012, 03:06 PM
  2. chlorine generator reading low salt
    By Mrs Lauzon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-05-2012, 05:54 PM
  3. Chlorine generator question
    By Jacob99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-25-2011, 11:56 AM
  4. Brine Chlorine Generator
    By Triangle in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2011, 12:51 PM
  5. Advice on Chlorine generator
    By Sean-NJ in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2006, 05:56 PM
