Ok... Good info....
Thanks,
Ed
With hot tubs there is the additional issue that the bacteria that causes hot tub itch, Pseudomonas aeruginosa, is more resistant to chlorine that most bacteria. I calculated that it would conservatively take 4 ppm FC at 20 ppm CYA to ensure killing this bacteria. That's about one week's usage of Dichlor and then switching to bleach (just keep track of how much Dichlor you are adding and when you've added enough for around 20 ppm or so FC then stop and switch to bleach alone).
The higher disinfecting chlorine level is about 5 times the mid-point in Ben's chart and is equivalent to 0.5 ppm FC if you didn't have any CYA (as opposed to most of Ben's chart which is equivalent to 0.1 ppm FC with no CYA). This higher level should also take care of oxidizing the "white stuff" you are seeing.
To reduce the smell of chlorine when using the hot tub, remove the cover about 5 minutes before you use the tub.
Richard
