Results 1 to 10 of 15
Thread: Need a "BBB For Dummies" Tutorial
    Default Re: Need a "BBB For Dummies" Tutorial
    We've written a number of self-helps on this.
    Here's another one:
    http://www.poolforum.com/pf2/showthread.php?t=3833
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    Exclamation Re: Need a "BBB For Dummies" Tutorial
    As for the Magic Eraser suggestion, I'd opt for some other method on your VINYL pool liner... something less abrasive.
    Kentucky
    Quote Originally Posted by Ohm_Boy View Post
    I'll agree on this - the Magic Eraser is fine for non-painted plastic surfaces (like steps). It is however quite abrasive compared with most cleaning methods. The magic is tiny plastic cells that actually scratch away the dirt, and can over time have a dulling effect on finished surfaces, and remove printing from the vinyl, or the paint from your coping.
    SoftScrub w/ Bleach and a non-abrasive scrubbie works great for the waterline in the spring for me.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Timer to motor and aquarite..."Y"or "T" fitting?
    By BND in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 03:59 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
