Thread: Drain line issues!! HELP
    Angry Drain line issues!! HELP
    Hi All,
    Recently started to drain the pool for a soon to happen vinyl liner replacement. The pool draining was going fine.
    I got about 3/4 or more of the water out and had been draining through the bottom drain and out the backwash of the filter.
    Two days ago, the pump lost prime. Reprimed, restarted and no go.
    I have shot water down from the pump side and see it push air out of the floor drain. Ran a snake up from the bottom as far as I could and seems to be open.
    Filled line with water from pump side and started. Pump is working as it sucks all the water out of the basket and pipe, but then goes dry. After it is dry, there is a ton of sucktion trying to remove basket cover.
    What should I do??? Do I have a clogged or broken waist line? How do I tell / fix???
    Scott
    Jul 2006
    Default Re: Drain line issues!! HELP
    I don't know if it has anything to do with it,but if you are draining that much water, shouldn't your filter be set at waste as opposed to backwash?
    Indiana.
    Once the water gets so low the pump will have a harder time lifting it. The difference in height between the water level and the inlet of the pump is the key, and pool pumps aren't really designed to do a lot of lifting of water. Probably no plumbing problems.
    Jul 2006
    I guess its time to buy a submersible pump.
    Filter has two settings, operate and backwash (Waist).
    My theory was that the pump would not be able to lift the water and it appears that is what happened. It stopped pumping when the water level got about 4' below ground level.
    Finished pumping with a small submersible, now just waiting to have the liner replaced.
    Jul 2006
    oh, ok, I guess some filters have a seperate "waste" option that bypasses the filter all togther. Seperate from a "backwash" option.
  1. In Line Chlorinator Issues
    By kyleyarusites in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-14-2011, 09:27 AM
  2. return line issues
    By plcguru in forum Pool Equipment & Operations
    Last Post: 06-16-2010, 11:39 PM
  3. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 06:34 PM
  4. Cutting main drain line to relocate equipment
    By JohnT in forum In-Ground Pool Construction and Repair
    Last Post: 05-08-2007, 09:57 AM
  5. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
