Results 1 to 10 of 11
Thread: Is Pressure guage important?
    Jul 2006
    Default Re: Is Pressure guage important?
    That's interesting. I'll tinker with it. Thanks!
    ePoolUser- Steve
    Nashville, TN
    27'x52 AG
    Honesdale PA
    On those gauges with the two screws in the back, the faceplate will unscrew or snap off and you can get to the guts. However, most cheaper gauges are sealed so they're a throwaway item. I also don't know whether the expensive stainless gauge would be worth it especially in a climate where it can freeze. One freeze and it's ruined just the same as a $6 cheapie.
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Default Re: Is Pressure gauge important?
    Just FYI, the stainless steel gauge I mentioned in my post above is liquid filled (with glycerin), so it may be less susceptible to freezing. In addition the wetted parts are 316SS alloy which is reasonably resistant to corrosive environments including salt water, particularly with the level of CH we typically see in pools with the calcium providing a layer of corrosion protection for the metal. I'll try to remember to provide some reliability feedback after a year has passed.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Morris, IL
    Our hydrostatic pumps that we used to use to test watermain for leaks used glycerin filled guages, we tested watermain whenever we put it in, summer, winter, whatever. The pump sat in the back of the truck, sometimes for days at a time, in even below zero actual temps. The guage remains fine. My only recommendation is that they sell guages that go up super high, while it will still work, you won't get the accuracy of one that only goes up to say 30 pounds, the increments are larger and easier to see. Grainger would have them for sure, or even any good plumbing supply. And yes, you can walk in off the street, and wave cash around, and they will sell to you.
    steve
    Honesdale PA
    Thanks for the info guys. Been trying to think of a way to keep water out of solid state pressure transducers and an inert liquid on the transducer side seperated from the water side by a non-permeable membrane may be the trick. Part of a pump control circuit to protect against over and under pressure. Been in the thinking stage for a couple years. All related to my paranoia of running a pump on a timer and unattended.
  1. Pump plumbing - Straight Pipe Important???
    By jaimslaw in forum Pool Equipment & Operations
    Last Post: 05-22-2011, 10:18 AM
  2. Remove pressure guage from filter?
    By Tishabiondy@natlmail.com in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-21-2007, 08:45 PM
  3. interesting re: pool pump wire guage
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 02:20 PM
  4. Important PS234 Info
    By PoolDoc in forum DPD-FAS based testing
    Last Post: 05-24-2006, 02:20 PM
  5. Pressure guage under pressure!
    By rustypixel in forum Pool Equipment & Operations
    Last Post: 05-02-2006, 02:56 PM
