Re: Do solar panels really work?
We have 4x40 feet of panels and live in a very northern area with cooler nights. Using the solar cover to keep the heat IN really helps but the thing is that just using the panels listed above, my pool will stay right about 85 and above for most of the season. Hooking them in immediately raised the water from the mid 70s to the 80s within a couple days of the pump running from appx Noon - 7pm. We had a lot of days we had to run the panels at night to cool the water down as 95 and over does not feel refreshing. End of last summer we ran on just 3 of the 2x20s due to damaged panel (replaced now) but had water that stayed over 80 and usually over 85 until the nights hit the 40s again.
So the short answer is YES, it will help. If 240 is all you can fit, then go with 240 sq ft.
