Thread: Dry well to help drain off well water....
    Southern Ontario
    Default Dry well to help drain off well water....
    we have problems with ground water around our IG pool in spring and after heavy rains in the summer. For years we have used a siphon pump placed behind the liner to remove it when necessary. Over the past couple of years, we've noticed that some new pool installs have a dry well set up close to the perimeter of the pool, and its covered over with a cover similar to the skimmer cover. We were wondering if we could dig a hole just outside of the cement apron around our pool, place in a large plastic tube liner, fill part way with stone and use this to drain ground water away from behind our pool. Has anyone done this? I think it would be about 3-4 feet away from the edge of the pool. Thanks in advance for any thoughts or input!
    Southern Ontario
    Default sorry meant dry well to drain off ground water!!!!
    whoops...I meant ground water not well water.
    Indiana.
    Default Re: Dry well to help drain off well water....
    Normally such dry wells are placed in the backfill for the pool, which is where the ground water tends to accumulate. It would probabl depend on your soil type whether one adjacent to the pool like that would help.
    I have one under the deep end of the pool and I can valve it in to the main circulating pump and pump it to waste to remove that water than would otherwise get behind the liner.
  1. should I drain some water out?
    By mrszaff in forum Dealing with Algae & Slime
    Last Post: 06-08-2013, 12:31 PM
  2. drain water from the skimmer?
    By Racker in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 12-03-2012, 07:51 PM
  3. Intex pool: can I fix the water or do I drain?
    By swimg in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-13-2011, 01:22 PM
  4. How much water to drain?
    By msb1766 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-16-2006, 09:40 AM
  5. Treat water or drain?
    By jimk0512 in forum Dealing with Algae & Slime
    Last Post: 07-30-2006, 03:37 PM
