Results 1 to 10 of 13
Thread: Pics of damage, need advice on wall damage
    Default Re: Pics of damage, need advice on wall damage
    Far more than I care to think about. Many times I have seen pools that were set in the ground and left empty just long enough for the walls to cave in. We dig the wall out, lay it on the concrete and pound it flat again.
    Severe rust is the only reason I would replace a wall. Anything else can be flattened out or repaired.
    If you feel, even after making the wall flat again, that it could still be a little weak in that area, you could reinforce the inside of the pool with 12” flat aluminum or metal flashing. Just insert it into the bottom rail inside the wall and tape into place.
    Based only on what I have seen in your photo I think the wall is fine.
    Best of luck, Dennis
    That wall is fine, however, it tells me the ground under it isn't - it needs to be PERFECTLY level - which it definitely isn't.
    I would install a sand cove with a ring of vapor barrier taped to the wall and laid on the floor onto which to build the cove - it'll stop any attempt at wash out...
    I was wondering if it looked like it heaved under the bottom rail. There were some pics last year where someone had a wall that was heaving up like that and Dennis or someone had recommened scraping the area under the rail to level with an impliment (that pool was still full) and that pool wall had settled right back to straight after that - since this one is not full, getting it to level along there should not be hard. It may be just that one area?
    Quote Originally Posted by matt4x4 View Post
    That is the side where the seams let go and all the water rushed out, so I'm sure the ground underneath is pretty wrecked. The wall doesn't appear buckled like that elsewhere.
    Just wondering if possibly, the liner was installed somewhat offset, adding downward pressure to the wall there (thus the crush buckle as well as the stress tear in the liner...). Do you remember if your wall/floor seam on the liner was relatively even all around, or was it further from the wall edge in certain places?
    Just like the hoffman's pool, liner was off center, one side would not stretch to fill space behind liner, liner thus pulled wall down. In your case, it may well have filled the space behind it, meaning the liner had just enough stretch in it, but was stretched to it's maximum capacity, winter shifting may have pushed it beyond it's limits, thus it let go.
  1. Hurricane Sandy Damage - Need Advice!!!
    By hamroy in forum --cleanup--
    Last Post: 11-05-2012, 04:42 PM
  2. Above Ground Pool with some holes and slight damage. I need repair advice.
    By rickbehr in forum Above-Ground Pool Construction & Repair
    Last Post: 04-06-2012, 12:18 AM
  3. Aluminum wall panel damage
    By bruizer in forum In-Ground Pool Construction and Repair
    Last Post: 11-14-2009, 06:11 PM
  4. Motor damage
    By JonnyG in forum Pool Equipment & Operations
    Last Post: 05-24-2007, 10:00 PM
  5. Replies: 3
    Last Post: 04-14-2007, 04:02 PM
