Results 1 to 10 of 13
Thread: Pics of damage, need advice on wall damage
    Default Pics of damage, need advice on wall damage
    We finally got our pool installer to come by and inspect the damage we had this winter. They got right into the pool and sure enough, there are 3 failures on the seam. He also said the pool wall needs to be replaced. Having bought the pool at a discount place, I think we're in for a disappointing time getting any warranty satisfaction on this beast.
    I apologize for the size of these pictures, but I didn't see a way to size them.
    Default Re: Pics of damage, need advice on wall damage
    Any tpye of warranty from the installer on their work? Was it for sure the liner that failed on a seam or was there something wrong with the cove that caused the liner to split at the crease of the cove? Did the wall buckle from the water leak/spill or from frost heave?
    You have my sympathy - its a mess. I sure hope things turn out the best for you and you can get back to your backyard paradise very soon.
    The heat seam on the liner let go in those spots, according to the installer. We've spoken with the liner manufacturer and he did tell us that if it was on a seam they would replace it free of charge, but now the installer is saying the wall is too buckled to save. I was really hoping the wall was going to be OK.
    Is that pic above the worst of the wall damage? If it is, I had worse the night before we filled and a storm came up blowing the walls over backwards and some parts forwards, leaving creases and folds. We were able to take 2x4s with blankets and the wall in between and pound the creases out. You can't even see where any of that was now. How are your bottom rails? Good yet? Is it just wall damage? with bends and folds?
    Maybe Dennis can give his opinion, I'm betting he has encountered some damaged pools with walls that buckled like that.
    Far more than I care to think about. Many times I have seen pools that were set in the ground and left empty just long enough for the walls to cave in. We dig the wall out, lay it on the concrete and pound it flat again.
    Severe rust is the only reason I would replace a wall. Anything else can be flattened out or repaired.
    If you feel, even after making the wall flat again, that it could still be a little weak in that area, you could reinforce the inside of the pool with 12” flat aluminum or metal flashing. Just insert it into the bottom rail inside the wall and tape into place.
    Based only on what I have seen in your photo I think the wall is fine.
    Best of luck, Dennis
    That wall is fine, however, it tells me the ground under it isn't - it needs to be PERFECTLY level - which it definitely isn't.
    I would install a sand cove with a ring of vapor barrier taped to the wall and laid on the floor onto which to build the cove - it'll stop any attempt at wash out...
    Jul 2006
    Its sad to see all these AGP's with spring damage. It seems the key is to get that liner lined up properly as there is a small margin for error.
    On an engineering standpoint, I find it interesting how the relationship between the water/liner/floor and walls all make it a stable structure, without one, it all falls apart.
    Default Re: Pics of damage, need advice on wall damage -- UPDATED
    Well, I'm pleased to say that the pool company we bought from promptly offered to replace our wall and liner free of charge -- although their contention is that frost heaving caused the damage. We'll still have to foot the bill for installation and for water (ka-ching), but it's nice to have this go our way, at least.
    Well thats great news and all is not lost. You should be back to being the proud owners of an operating pool in no time.
    looks like coving was washed out
  1. Hurricane Sandy Damage - Need Advice!!!
    By hamroy in forum --cleanup--
    Last Post: 11-05-2012, 04:42 PM
  2. Above Ground Pool with some holes and slight damage. I need repair advice.
    By rickbehr in forum Above-Ground Pool Construction & Repair
    Last Post: 04-06-2012, 12:18 AM
  3. Aluminum wall panel damage
    By bruizer in forum In-Ground Pool Construction and Repair
    Last Post: 11-14-2009, 06:11 PM
  4. Motor damage
    By JonnyG in forum Pool Equipment & Operations
    Last Post: 05-24-2007, 10:00 PM
  5. Replies: 3
    Last Post: 04-14-2007, 04:02 PM
