Results 1 to 9 of 9
Thread: HTH Cal-Hypo Duration Tabs
    Charlotte, NC
    Default HTH Cal-Hypo Duration Tabs
    Anyone have any experience with these in the skimmer? I am using 6% bleach 100% of the time but want to supplement when I am out of town 3-4 days.
    Default Re: HTH Cal-Hypo Duration Tabs
    If they are the type wrapped in plastic like a capsule, and you throw the capsule away when it's empty, supposedly they work well.
    If they are the type that looks like a caplet, save your money--they turn to mush in 6-8 hours and clog your skimmer--that's personal experience talking. They are pure garbage and do NOT work as advertised. I tried it. I know.
    Charlotte, NC
    I just read learned about it yesterday so I am not sure which kind but I will certainly stay away from the "caplet" variety. I need a non-stabilized puck (I like to keep my CYA level under 20) and my CH is not a problem so the calcium based product seems like a good idea for vacation time.
    A sister company/brand of HTH now makes the plastic covered capsules, but I'm darned if I can remember the name. (sorry, it just came back to me that that is where you get them).
    Stay away from the HTH Durations.
    Charlotte, NC
    Thanks Carl.
    The other company that Arch Chemical has is Poolife. Both HTH and Poolife have cal hypo tablets. HTH are the Duration ones and Poolife are the Active Cleaning Caplets, The chlorinating caplets, and the briquette shaped Active Cleaning Tablets. Have never used any of them so I can't tell you which is which. The HTH product is designed for Skimmers. The Poolife caplets are for skimmers or floaters (CLEAN, NEW ONES THAT HAVE NEVER HAD TRICHLOR TABS IN THEM!), and I don't know about the Poolife tablets.
    Hope this is helpful.
    Edit: The Poolife Active cheaning caplets are supposed to last for 2-5 days and if my memory serves me correctly so are the Duration Tablets. The Duration Tablets we got in this year say "New and Improved" on them so maybe they got them working right again.
  1. Floater Tabs
    By TheKs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-14-2012, 08:20 AM
  2. Bleach VS Tabs
    By samtex in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-14-2011, 01:15 PM
  3. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 07:12 PM
  4. hth 3 in 1 tabs
    By fish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-16-2010, 08:23 PM
  5. Finally found a use for Duration Tablets
    By CarlD in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-06-2007, 12:36 PM
