Thread: No filtration yet but here are the numbers
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    Wink No filtration yet but here are the numbers
    We uncovered our pool to find it clear with only a few leaves..yippee! We've started to fill but aren't quite ready for the pump yet. Should I add a stabalized puck to float around or any bleach/pooltrine 60 to keep it that way? I'm a little nervous it may turn green if I can't get the pump installed in the next two weekends. Thanks in advance for any help.
    Here are my numbers:
    FC=0
    CC=0
    PH=7.6
    CYA=30
    TA=100
    CH=20
    Claudia
    18' Echo Canyon A/G Pool by Artesian
    8500 gallons
    3/4hp Jacuzzi 2-speed pump - Cartridge Filter
    Default Re: No filtration yet but here are the numbers
    Yes - if it is going to be a couple of weekends before you get the equipment hooked up. It is amazing how quickly algae will get started. If it were my pool, I'd add a little bleach every couple of days and stir it around with a clean broom.
  1. pool filtration
    By ladypoolfool in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 03:43 PM
  2. UV Pool Water Filtration
    By Pibster in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-25-2012, 12:18 PM
  3. Filtration / Run Time...
    By The Crow in forum Pool Equipment & Operations
    Last Post: 04-15-2012, 09:57 PM
  4. Baquapur Filtration System
    By DEBKNTX in forum Above-Ground Pool Construction & Repair
    Last Post: 05-28-2010, 06:52 AM
