Results 1 to 10 of 15
Thread: BBB and Vacation Maintenance
    western Washington state
    Default BBB and Vacation Maintenance
    I tried finding a post with this info but couldn't so here goes.
    I will be entering my second season with BBB pool maintenance (16X32 AG with deep end and surround decking). I haven't opened yet but plan to soon before the warm weather breeds algae and pea soup.
    My question...We'll be going on a trip mid June for about 10 days. How do I maintain the chemistry using BBB when I'm not going to be around to dump Clorox? I have a solar cover and the solid winter cover and a chlorine feeder that I don't use with BBB.
    CoffeeBean
    Indiana.
    Default Re: BBB and Vacation Maintenance
    Last year we took a two week trip. I intentionally left my CYA low on startup. It was 20 until June when we left. I filled the chlorinator before I left and showed a neighbor how to refill it. Came back to CYA of 35 and a clean pool.
    I set up a VERY simple maintenance system while we are away. I have my father-in-law do 2 things every other day:
    1) Empty the skimmer
    2) Add 1/2 gallon of bleach into the skimmer.
    I add it the day we leave and leave him 6 gallons for 2 weeks. I leave the pool covered with the solar cover, and the pump timer set so it's always running when he's there.
    I always come back to a perfect pool.
    John T: How long had you had the pool up and running with a low CYA before you left? Did you swim in it before leaving?
    CarlD: I'm taking my father with us so there won't be anyone here to mess with the pool at all. I'm leery about having the pump running with no one around too but I'm afraid that if I wait until we return to open, I'll have a green mess. I did that one year. Yuck.
    Can I put CL pucks into my in line chlorinator just for the time I'm gone or will it totally mess up the BBB?
    Thanks guys.
    CoffeeBean
    Indiana.
    Quote Originally Posted by CoffeeBean View Post
    We started swimming in late May, so we'd been swimming 4 weeks when we left. The only issue with the lower CYA was that I usually added bleach when I got home from work instead of waiting until we were done swimming for the evening to maintain chlorine.
    Thanks guys.
    CoffeeBean
    The only negative affect they'll have is adding CYA and tending to lower the pH. If you can get your CYA low enough before you go, you'll be fine. Many people use pucks when they open to add CYA, then switch to bleach when the CYA gets where they want it. I've just settled on 35ppm because my pool always has FC high enough after the sun goes down.
    If you don't run the pump, you'll be sorry. I have a timer now, but I used to have a neighbor turn it on one morning, then off the next. That way I got some circulation without it being too big of a pain for him.
    I thought about putting a timer on the thing a couple of years ago so that the pump's not running 24/7 but...when I investigated the idea I read that it wasn't a good idea. I cringe now but I was still enslaved to the pool store, when I checked with the pool stores they both said the same thing. Couldn't exactly tell me why though.
    Where in the set up is yours, how does it connect to the pump, and how do you waterproof it? Is it a special timer or just one you'd put on your lamps? How many hours a day do you run it? Sorry to shoot questions at you but I'm curious since it seems to work for you despite the pool guys dire warnings.
    CoffeeBean
  1. Lack of Maintenance - Need Help Please
    By rikper in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2009, 09:11 PM
  2. Looking for Minimal Maintenance
    By JimSentry in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-26-2006, 10:33 PM
  3. Maintenance Polyquat?
    By csevel in forum Dealing with Algae & Slime
    Last Post: 06-14-2006, 10:56 PM
  4. regular maintenance help
    By poolhelp101 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-16-2006, 09:36 AM
