Thread: Are some robots better than others with gunite?
    Default Are some robots better than others with gunite?
    Good Evening All...
    I recently purchased a home with a gunite pool. My last two homes have both had vinyl 20X40 inground pools. For the record, my new pool is significantly smaller. I believe the builder called it an "oasis" pool with a elevated spa. In any event, I have a Polaris 360 (that was left with the home when I purchased it), and a Aquabot clone (I purchased it from intheswim.com), and it looks exactly like the aquabot but has in the swim's name on it. I bought it a few years ago for about $1200, and it did fine in my last pool. That said, it really doesn't seem to be picking up as much as I feel it should with my gunite pool, and it seems to get stuck ALL THE TIME!!!!!! I never had this issue with my vinyl pools.
    My question is this...Are some of the automatic cleaners better for gunite pools, and if so, which ones? I need to figure out a solution before this babysitting of my pool cleaner drives me nuts! Any and all feedback is most appreciated.
    John from Boston
    Default Re: Are some robots better than others with gunite?
    Hmmmmm....I guess I'm the only one who has a tempermental robot!
    John from Boston
    JonnyG is offline Registered+ Thread Analyst JonnyG 0
    I have a Zodiac Mars HP with my pool and I absolutely love it
    (never used my vacuum last summer). Although it needs to plumbed up as it required high pressure water to run (it has a separate pump). Sounds like it may be too late for that for you?
    John
    JonnyG (Hunterdon, NJ)
    30,000 Gal IG Shotcrete (Carlton Pools)
    SW Generator
    6ft Sheer Descent
    Jandy equipment (60sf DE filter)
    Zodiac Mars booster pump cleaner
    Teledyne Lars 400,00 Btu heater
    BBB believer
  1. Recommended cleaning robots?
    By bellbound in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-24-2012, 12:38 PM
  2. Gunite already calcium deposits and small hairline cracks of both plaster and gunite
    By getittogether in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2011, 01:45 PM
  3. Gunite in 100+
    By mmcguire in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2006, 07:42 PM
  4. Robots vs. Manual
    By cheshamjim in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-14-2006, 01:08 PM
  5. Shotcrete vs Gunite
    By DaBomb650 in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 03:52 PM
