Thread: Northstar or Whisperflo???
    Default Northstar or Whisperflo???
    Hi All,
    Trying to decide between these 1HP pumps. Any thoughts or advice?
    Thanks,
    Joe
    mas985's Avatar
    Pleasanton, CA
    Default Re: Northstar or Whisperflo???
    Both are great choices and really you can't go wrong with either one. Northstar has a very slight efficiency edge but the Whisperflow can handle a bit more suction loss without cavitation. Whisperflow is also easier to find as two speed version.
    Also, if it is a new pool, you might want to stick with all the same equipment since you can get a free extended warranty that way. Otherwise, you might want to go with the best price.
    Mark
  1. Northstar pump motor replacement
    By masksav in forum In-Ground Pool Construction and Repair
    Last Post: 04-01-2012, 06:13 PM
  2. Hayward Super II or Northstar?
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 09-23-2006, 05:19 PM
  3. Hayward Northstar pump install: Review
    By pj1016 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 11:46 PM
  4. Northstar strainer cover
    By nu2pools in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 09:38 AM
