Quote Originally Posted by SPILL View Post
Questions, should I be worried about the high CC? I believe this is telling me that the conversion is working and 'eating' up cl.
you are right. The CC is because it is eating the baqua
The DE filter is gumming up quickly, cleaned and replaced the DE today, one hour later, barely any flow, if i bump it I can get a little pressure for an hour or so. Should I by pass?
In my understanding, you have to filter the goo out. If you bypass, you will not be filtering it out, and the conversion will, at best, take longer.
I am aware I need to keep testing and keep at it, just concerned about the filter and the CC.
Any advice is appreciated, can't wait to get off the Baq.
Not sure what else you should do about the DE, as I am only familiar with sand and cartridge filters...
