Hi, sorry I was away from a computer. I know that this is tricky - I would add a maintenance dose of metal sequester, and add water. It is ok to add more metal sequesterer than it says. You should not have any algae, as your chlorine is fine. I wouldn't worry about the green for now. It is normal for the water to cloud again after vacuuming to waste when there is a lot of sediment in the pool. Now I would leave the filter on 24/7, and use the skimmer sock - you can also put in some DE to make your sand filter more efficient, add 1 cup to a bucket of water and mix it up - add it directly to the filter. If your filter pressure doesn't go up, you can add another cup. Just make sure you add it to water before you put it in the skimmer. Then just let it keep filtering - it will clear up. Make sure you keep an eye on the filter pressure, and backwash as needed. If you backwash, you have to add more DE if you are using it, as it will backwash out. I know this is confusing, but it will clear - you just have to have some patience. If you don't see any clearing in a day or two, then we will try again. Just a though, are you sure your filter is working properly? Just trying to cover all bases
