You had reported in this thread how you are using BBB and had CYA too high in the past and may have had the bacteria, Pseudomonas aeruginosa, that causes "hot tub itch". This bacteria takes a lot of chlorine to kill. From what I have read, it would take 0.25 ppm FC with no CYA which is equivalent to an FC of 9.6 ppm with a 40 ppm CYA level. So I would suggest shocking with chlorine even higher to 20 ppm and holding that level for a full 24 hours. Then let the chlorine level drop before going back in to swim. Also, be sure and wash all of your swimsuits since this bacteria tends to get transferred from place to place via swimsuits. I'm not sure if there is an anti-bacterial soap you can use during the washing but if hot water is used it has to be very hot to be effective (120+ degrees) since the bacteria actually thrive in hot water of 99F and are able to grow in up to 108F. You might even consider replacing your swimsuits.
As for your pH issue, do you have any waterfalls or other aeration features in your pool? With a lower TA of 70 you normally would not be seeing a pH rise, especially not with BBB. SWG pools tend to see more of a pH rise due to the aeration from the hydrogen gas bubbles that are produced in the SWG.
Richard
