Thread: Curing of Concrete
    Maryland
    Default Curing of Concrete
    My wife was just told by one of our pool builders workers that when the concrete deck is poured we can't put anything on it, patio furniture, BBQ or things that are even lighter for 30 days.
    I know one needs to allow concrete to cure for a certain amount of time but 30 days seems a bit much. Anyone else have a restriction this long?
    Jul 2006
    Default Re: Curing of Concrete
    wow 30 days is long, i think after a week should be fine. The key word is cure not harden. Don't forget to keep the new concrete wetted down as it will cure better and not dry out too quickly.
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    If you do have to be on it. you can lay a sheet of plywood down to distribute the load so that there are no 'point' loads on the concrete.
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    There might be some confusion here between the gunite and the deck. I have a friend who makes concrete homes and basements for a living and he said there should be no problem using the deck after a few days. However, 30 days is about how long gunite should cure before adding water.
    beary
    The hardness of concrete is typically stated based on a 28 day cure. You should not subject it to heavy use before then.
    Jul 2006
    I was told 24 Hrs before i can walk on it....
    I waited 48 and moves some lite padio furn. on it...
    GutierrezPlastering Guest
    I also pour concrete decks, and concrete is safe to walk on after about 4-8 hours after broom finish and you may put furniture on the deck just to be safe 3-4 days later and it takes 27 DAY to reach its MAXIMUM HARDNESS STRENGTH
  1. concrete deck mix?
    By jdolby in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2012, 02:28 PM
  2. Closing with curing plaster?
    By JJParrish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-05-2007, 05:40 PM
  3. Curing new plaster?
    By JJParrish in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2007, 12:21 AM
  4. Concrete refinishing
    By VOLDADDY in forum In-Ground Pool Construction and Repair
    Last Post: 12-07-2006, 02:55 PM
  5. Curing Shotcrete
    By HAYMAN in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 11:32 AM
