Shortened question:
Would I cause damage to my 19" sand filter if I used a 1.5hp pump on the unit for a couple of weeks?
Lengthened explanation:
I purchased a new 19" Waterway sand filter and a 1hp 2 speed pump for it. The filter arrived within a few days but the pump had to be drop shipped from Waterway. It was over 2 weeks before the pump arrived.
Then when I have everything setup and ready to go I turn on the pump and all it does is hums. I removed the pump from the system, opened up the wet end, and tried to turn the impeller. It is very hard to turn for some reason. I have a feeling it’s going to be a while before this is settled.
My pool is suffering big time and turning swampy. I was keeping it somewhat under control with the old filter system but the tank has a crack so I could only use recirculate. I would like to get some filtration going and start the cleaning process. This is why I am inquiring on whether the 1.5hp pump will hurt my new filter.
What do you think?
Thanks y’all from a frustrated pool owner who is awaiting the moment something goes right with the filter system.
