Yikes, I pulled open a corner of my pool cover off and took a sample to quickly test PH and TA from my 23K G gunite and was shocked to see my TA test go red after ONE DROP!
The PH was 7.0, which is the lowest I have ever seen it since the pool was replastered five years ago. I usually have problems with PH and TA being too high, but last season I was having some PH and TA bounce issues which I thought I had under control.
I'm in the process of bring the TA back up now, but can anyone speculate on why the TA would crash from a normal reading in the late fall after it was closed for two months (I forget exactly, but it was fine) to something below what the test kit could measure?
The real kicker is that if the CYA test is right, it wasn't dilution that caused the TA to drop. Any chance that the algae in the water is causing a problem with the CYA test due to extra crud in the water?
