Thread: PVC repair adapters?
    keithw is offline Registered+ Thread Analyst keithw 0
    Default PVC repair adapters?
    Has anyone heard of a PVC adapter that you could install inside of an existing pipe to repair it? For example, say I had a run of 2" PVC coming out of a cement pad. say it was cut off flush with the cement pad so none was stick above it. Is there an adapter that you could cement into the inner diameter of the pipe to extend it back up and give you a section that you could use again?
    Default Re: PVC repair adapters?
    Yes, there is such a thing. It should be available at any "big box" hardware store. Tell them you need a "male" splice coupler.
    Dave
    I will check with them again. Last time I ask, they pointed me to the M/M coupler that goes on the outside of the pipe.
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Check this link for an Inside Pipe Coupling/Connector. Comes in 1", 1.5" and 2". This site also has a number of other unusual PVC fittings.
    http://www.plumbingsupply.com/pvc.html
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Cool Re: PVC repair adapters?
    Kieth, what you want is a 'pipe extender' this post talks about them (the rest of the thread talks about making your own).
    {edit: catnip gave the same place - I GOTTA get quicker with my typing!! }
  1. Skimmer Repair
    By turney in forum In-Ground Pool Construction and Repair
    Last Post: 07-07-2012, 03:32 PM
  2. Mastic for Repair?
    By TamiA in forum In-Ground Pool Construction and Repair
    Last Post: 06-11-2012, 09:15 AM
  3. Intex to standard adapters (thought I'd share)
    By Mwil3 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2011, 12:49 PM
  4. Pump repair
    By tommykrash in forum Pool Equipment & Operations
    Last Post: 04-10-2011, 12:41 PM
  5. Spa Seat - Jet Repair
    By SteveK2 in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2007, 02:09 PM
