Thread: CH Test Questions/ CH Rising
Threaded View
  1. #3
    Miami, Florida
    Default Re: CH Test Questions/ CH Rising
    Thank you for your quick response. Went out and did as suggested (11:30 am) - numbers are as follows:
    CL 6.0 TC 6.0 Ph 7.6 Alk 80
    Air Temp 82 Pool Temp 82
    CH 525 again - still had the floating particles in the end result. I want to say the change in color was more easily discernible but not really by much.
    As for the brown stains - the vitamin C took them away real quick.
    So - I'm not sure if I get this but it looks like:
    1) Brown stains are iron - which vitamin C will take away obviously. But can you only treat the individual spots or can you treat the pool in general to remove them and prevent them in the future? Why is it happening in the first place?
    2) The particles I see are caused by magnesium - which is related to my elevated calcium hardness levels. And the iron stains are also a byproduct of the CH? Any ideas why this is happening in the last few months...
    3) Do I need to test for metals then - how/where do you do that? Please, please don't say the pool store...yikes!
    I don't just want to fix it I want to know why it's happening so I can prevent it if possible. Thanks again.
    Gracy
    Gracy
    16,725 gal gunite pool/1000 gal spa;exp agg finish; Jacuzzi 2 hp pump/Hayward cartridge filter/electric heater; Taylor K2006 Test Kit
  1. My first test... questions
    By gogolion in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2012, 09:32 AM
  2. Test results and questions
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2009, 01:14 PM
  3. 1st test results of spring - few questions...
    By court475 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2009, 02:37 PM
  4. test results and SWG questions
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 01:27 PM
  5. Test Results questions
    By DaveInPA in forum DPD-FAS based testing
    Last Post: 05-30-2006, 11:50 PM
