Thread: CH Test Questions/ CH Rising
    Default Re: CH Test Questions/ CH Rising
    Quote Originally Posted by Gracy101 View Post
    Now to my main problem with CH test/results (besides the incredibly high number).....
    1) when I add the 5 drops of R-0011L Calcium Indicator, my sample turns decidedly pink not red. Is that a problem?
    actually, it's supposed to turn pink
    2) when adding the R-0012 Hardness Reagent, obviously my sample does not change from red to blue. Instead the pink color seems to "break up" into little particles floating in the water sample. I keep adding drops/swirling and eventually the water does begin to turn blue but the floating pink particles remain in suspension - reading at 525. What is happening/has happened?
    This is often caused by metals in the water but it can also happen with no metal present but very high magnesium levels. It's a common interferance to the calcium hardness test. Nothing to worry about and easy to fix! Try adding 2-6 drops of the hardness reagent BEFORE adding the hardness indicator and then continue the test but count those drops added in your total. You should find that you get a definite end color without the interfenace. Here is the procedure:
    1) add the 20 drops of calcium buffer and swirl
    2) add 2-6 drops of hardness reagent (for this example let's say you added 6)
    3) add your 5 drops of indicator. The solution should be pink.
    4) Titrate with the hardness reagent until the color changes to blue. for this example let's say it took 28 drops.
    5) add the initial 6 drops and the 28 drops for a total of 34 drops which would be 340 ppm calcium hardness.
    BTW, my fill water tests at 90 and there are no floating particles so I don't think the problem lies with the age/quality of the reagents, right?
    I know I need to drain and refill to lower CH but beyond that, these particles and what they represent have me worried....
    Also while the pool water looks clear to me overall, when I conduct the chlorine test it and the water turns from pink to clear, the water in the tube seems cloudy. Is this significant?
    NO, this is also normal.
    And lastly - today I noticed a few brown stains on the walls of the spa, each a couple of inches in diameter, right by the steps. Are they part of all this?
    Could be iron stains, which would explain the interferance you are getting with the calcium test. Try holding a vitamin c tablet on them and see if they disappear. If they do they are iron. Easy to fix, just post your results and we can help.
    Sorry this is kind of long but I've tried to give a complete picture - can anyone help? thanks in advance.....
    Gracy
    Hope this is helpful.
    Miami, Florida
    Thank you for your quick response. Went out and did as suggested (11:30 am) - numbers are as follows:
    CL 6.0 TC 6.0 Ph 7.6 Alk 80
    Air Temp 82 Pool Temp 82
    CH 525 again - still had the floating particles in the end result. I want to say the change in color was more easily discernible but not really by much.
    As for the brown stains - the vitamin C took them away real quick.
    So - I'm not sure if I get this but it looks like:
    1) Brown stains are iron - which vitamin C will take away obviously. But can you only treat the individual spots or can you treat the pool in general to remove them and prevent them in the future? Why is it happening in the first place?
    2) The particles I see are caused by magnesium - which is related to my elevated calcium hardness levels. And the iron stains are also a byproduct of the CH? Any ideas why this is happening in the last few months...
    3) Do I need to test for metals then - how/where do you do that? Please, please don't say the pool store...yikes!
    I don't just want to fix it I want to know why it's happening so I can prevent it if possible. Thanks again.
    Gracy
    Gracy
    16,725 gal gunite pool/1000 gal spa;exp agg finish; Jacuzzi 2 hp pump/Hayward cartridge filter/electric heater; Taylor K2006 Test Kit
    Iron can come into your water from several sources. Well water is a common one but it can also be in city water. To treat a whole pool you need ascorbic acid powder. Search the forum for ascorbic acid and you will find the complete procedure posted many times. Look for posts by Mbar. She is the forum's resident 'stain expert'!
    The particles you are seeing is most likely caused by the iron in your water. Metals will cause this interferance in the test.
    If you don't want to go to the pool store then you will have to invest in a test kit for iron. Taylor makes an excellent one.
    Start reading the section of the forum called Stains & Metal Matters: Iron, Copper, Silver & More
    You will find a LOT of good info there!
    Gracy
    Hope this helps.
  1. My first test... questions
    By gogolion in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2012, 09:32 AM
  2. Test results and questions
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2009, 01:14 PM
  3. 1st test results of spring - few questions...
    By court475 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2009, 02:37 PM
  4. test results and SWG questions
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 01:27 PM
  5. Test Results questions
    By DaveInPA in forum DPD-FAS based testing
    Last Post: 05-30-2006, 11:50 PM
