Thread: Ideal Levels
    Sardian is offline ** No working email address ** Sardian 0
    Default Re: Ideal Levels
    You could hook up a hose to the cold side of your washing machine hook up and get water there and not put the strain on your water heater. Or, pick up a good Y connector from the lawn and garden dept at one of the Big Box stores (one that has the built in ball valves) and hook it up to your wm connector. This way you wouldn't have to disconnect your WM when you need to fill the pool.
    It was just an idea. I guess it all depends on where your WM is. I know my wife wouldn't want a hose dragged through the house every time I filled the pool ;-)
    Quote Originally Posted by iwannapool View Post
    I guess I could connect a hose to the house water heater drain to get soft water to the pool and spa. I would need to make sure that any calcium/lime that's in the bottom of the tank is cleaned out really well before putting that water in the pool.
    Thanks again for the help.
    Maryland
    Quote Originally Posted by Sardian View Post
    That's a great idea, I hadn't thought about that. Our washing machine is just inside the door from the garage so I could run the hose out though the garage to the pool without having the Mrs. getting too cranky.
    Thanks for the suggestion.
  1. Ph is ideal, alkalinity is a little high
    By Mftek1 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2013, 05:54 PM
  2. Waterco CC100 ideal pressure
    By pfgroth in forum --cleanup--
    Last Post: 12-14-2012, 07:32 PM
  3. Newbie: Ideal Pool Depth
    By mnittler in forum In-Ground Pool Construction and Repair
    Last Post: 10-02-2012, 09:29 PM
  4. CYA Reducing Mix Period/CYA Ideal Level?
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-12-2006, 01:14 AM
